Re: New Super A owner with a Starter Question
Posted by Doug on July 13, 2003 at 06:53:57 from (205.188.209.140):
In Reply to: New Super A owner with a Starter Question posted by New Super A Man on July 12, 2003 at 20:47:05:
Kevin, Take a real good look at both ends
of both battery cables. make sure there is no corrosion. make sure you have agood ground also.
I have a Super H that had 1 of the 2 bolts that
hold the bendix spring on the shaft strip causing
the starter to lock up. anyway, to check your starter, pull it off the tractor, use a set of jumper cables and hook the neg. to the terminal on
the starter and touch the pos. to the starter case
the starter should spin freely.Just make sure you don't ground the case first and then touch the neg.terminal because you might melt the threads on the terminal. If the starter checks o.k. by doing this I would suspect the battery cables or ground.Hope this helps and good luck
Post A Followup
: Re: Re: New Super A owner with a Starter Question
