Re: Farmall H leak
Posted by Michael Soldan on July 13, 2003 at 17:54:03 from (216.46.130.111):
In Reply to: Farmall H leak posted by IH Man on July 13, 2003 at 11:47:51:
I-H Man, you need to remove the liftall and then its a fairly simple task from there. You will need to unbolt the driveshaft and get it out of the way, the seal is inside of a threaded collar which will turn off with a small pipewrench. A screw driver will pry the old seal out and tap the new seal in and you are reassembling.I bought an H about 5 years ago and I changed the rear oil and topped it up where it was supposed to be and it started leaking all ove rthe shop floor...the seal was out of it and probably had been for some time, I don't have a liftall on this H so it was an after supper job one night....good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: Farmall H leak
