Re: Re: IHC plows
Posted by Farm w/Junk on July 14, 2003 at 18:58:47 from (157.134.184.64):
In Reply to: Re: IHC plows posted by Hugh MacKay on July 14, 2003 at 13:39:57:
Hi the first plow is a three bottom on steel with the spring hitch for a clevis. It has levers for depth. It is a clutch lift. It looks like it has an add on bottom. The second is a two bottom on rubber with hitch for a clevis. It has levers for depth. It is a clutch lift. It has canada stamped in the beam next to the trip lever. It also has 16 inch rims. The third is a two bottom on rubber with a hitch that uses a regular pin. It has levers for depth. It is clutch lift. It also has 15 inch rims. Were the three bottom plows just two bottom plows with an add on bottom? Thanks a lot.
Matt
Post A Followup
: Re: Re: Re: IHC plows
