Re: Re: LP Tractors
Posted by John A. PS on July 14, 2003 at 21:00:34 from (208.24.233.53):
In Reply to: Re: LP Tractors posted by John A on July 14, 2003 at 20:36:59:
Gary, Next time it gets to operating temp and you need to cut it off.
#1 Cut the valves off let the engine burn all the fuel from the line.
#2 When ready to start the tractor again
A. Start cranking the engine first
B. Slowly "crack" the Vapor valve. ONLY crack
this valve, and no farther, then shut off.
C. With your free hand, vasalate the sreering
wheel back and forth while turning the
engine over.
step C- Old 4020 LP trick. It has something
to do with reliving hydrolic pressure in
start-up.
D. When she Hits... open valve.
Good Luck,
John A.
Post A Followup
: Re: Re: Re: LP Tractors
