Re: Mounting one-piece wheel weights on an M
Posted by Jim on July 15, 2003 at 14:16:37 from (216.43.103.173):
In Reply to: Mounting one-piece wheel weights on an M posted by Lowell Davis on July 15, 2003 at 08:24:20:
Pretty simple with about 2 foot long ready bolt and a couple of nuts and washers. Roll the weight to the tire. Boost it so the ready bolt goes through the lowest hole on the hub and the top hole on the weight. Put on the washers and
nuts. Lift and turn the weight 180 degrees and attach the top bolt. Remove the ready bolt and replace with the final bolt. Does not require much lifting and holding. I am 62 and do them by myself. My 2 cents.
Post A Followup
: Re: Re: Mounting one-piece wheel weights on an M
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
