Re: Re: Re: Re: Blow by from oil stack- Super A
Posted by Ludwig on July 15, 2003 at 21:51:12 from (68.163.108.216):
In Reply to: Re: Re: Re: Blow by from oil stack- Super A posted by Hugh MacKay on July 15, 2003 at 13:42:03:
I agree with the other poster who says you can probably get by with just rings.
#1 thing though would be a compression test you might just need valve guides or a valve job. Either get a good thread in compression tester, rent one, or have a mechanic do it. Then do a wet test. Wet test is done by putting a teaspoon of oil in the cyl and testing again, if the compression raises noticably then rings are probably in order, if it doesn't then head work.
Remember when doing rings to get a ridge reamer and ream the carbon ridge at the top of the cylinder where the piston stopped all those millions of times over the years.
Post A Followup
: Re: Re: Re: Re: Re: Blow by from oil stack- Super A
