Re: Calcium Loading of Super M Tires
Posted by jal-SD on July 17, 2003 at 06:29:20 from (12.17.66.109):
In Reply to: Calcium Loading of Super M Tires posted by Doug Bunnell on July 16, 2003 at 18:46:25:
IMHO, I would never put calcium into tires. For more weight, add concrete or cast iron. Water is always dragging behind you, cast on the wheel puts the weight down on the tire, instead of pulling behind it. Used IH weights sell for about $30.00 - $50.00 per set in our part of the world. Lots less $$$ than a new rim. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Calcium Loading of Super M Tires
