Re: Re: Re: Difference between 560 D and 660 D
Posted by brian on July 18, 2003 at 05:37:29 from (206.159.154.246):
In Reply to: Re: Re: Difference between 560 D and 660 D posted by dmp on July 17, 2003 at 19:11:06:
In terms of the engine, the 560, 660, and even the 706 had the same basic components. They use the same block and same bore. I believe the stroke is a bit different, but most of the parts are interchangeable. If you put a 706 crank and rods in, then you would have an easy "stroke" job done. That will bump you up a bit. After that look at valve spings, and turn up the pump.
Post A Followup
: Re: Re: Re: Re: Difference between 560 D and 660 D
