Re: Farmall H steering parts
Posted by Bob M on July 18, 2003 at 11:17:35 from (165.170.128.65):
In Reply to: Farmall H steering parts posted by IH Man on July 18, 2003 at 06:52:16:
A boneyard is the cheapest source for a replacement steering worm and gear. The risk of course is the replacement gear set will be no better than the one you've got now. Your CIH dealer can supply new parts, but they're gonna be costly - probably $200 - $250 range - maybe more. If you are lucky the pivot shaft worm gear will be a full gear - with teeth all the way around. By removing the gear, turning it 180 deg and putting it back on the shaft, you'll bring fresh, unworn teeth into contact with the worm. However most of the H's I've looked messed with have had a half moon-shaped gear. This half moon gear has just enough teeth to rotate the pivot shaft between it's left and right stops. The gear cannot be turned to bring fresh teeth into contact with the worm. Suggestion: Before you buy some expensive gears, check carefully both the upper end of the pivot shaft, also the worm shaft for looseness or play. Often replacing the bushing at the top of the pivot shaft and tightening or replacing the bearing/bushing that supports the worm shaft will bring the worm and gear back into proper engagement and will eliminate steering slop. I did this to my Super H a couple years ago - it completely solved a front wheel wobbling problem. And the parts (two bushings and a seal) cost less than $30. Good luck!
Home
| Forums
Today's Featured Article -
Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
