Re: Re: Re: Difference between 560 D and 660 D
Posted by Brian in MO on July 18, 2003 at 16:17:10 from (216.73.199.174):
In Reply to: Re: Re: Difference between 560 D and 660 D posted by dmp on July 17, 2003 at 19:11:06:
As for turning the pump up get out your screwdriver and do it but you might want to put it on a dyno to see what hp you already have as most all of them have been turned on over the years. I had a 560d that the pump was rebuilt on and the shop that done it turned it to 85 hp but the tractor really didn't weigh enough without adding weight to to handle it well.
Post A Followup
: Re: Re: Re: Re: Difference between 560 D and 660 D
