Re: Farmall H magneto H-4 type
Posted by John on July 18, 2003 at 18:30:30 from (192.233.162.182):
In Reply to: Farmall H magneto H-4 type posted by Pat Connors on July 18, 2003 at 07:23:40:
Mine did the exact thing last week. It was running great, I was adjusting the carb and then it started to sound like a JD. My carb was just rebuilt, all new plugs, wires, points, etc. I cleaned up the new plugs, dressed the points and still sounded like a JD. I then decided to take the carb apart. I cleaned out EVERY part of the carb., I didn't see anything other than some particles in the screen. Put it together (used an IH carb. kit$$)and it sounds great!!!. The only problem I had was the carb started to leak where the optional plug drain is so I put in a brass plug and that solved that. Then yesterday the needle valve didn't work and I had a puddle on the floor, I put the old aftermarket needle and seat back in and I am fine. From what i am told the smallest speck of dirt can cause problems and I believe it.
Post A Followup
: Re: Re: Farmall H magneto H-4 type
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
