Re: Is my 51' H 6 or 12 volt?
Posted by CNKS on July 18, 2003 at 19:38:34 from (207.178.96.211):
In Reply to: Is my 51' H 6 or 12 volt? posted by Adam on July 18, 2003 at 11:32:28:
You sure it doesn't have hydraulics? Most came with a belly pump. The rod and lever could be missing. Remove the plate from the bottom of the torque tube (clutch housing) and look inside. If you see nothing but a clutch shaft, then you are right. You can add live hydraulics by using the pump (mounts in front of the distributer) from a Stage 2 Super H along with the cam gear.
Post A Followup
: Re: Re: Is my 51' H 6 or 12 volt?
