Re: Re: 674 Diesel (Hydraulic Problem)
Posted by Kevin Manring on July 19, 2003 at 10:10:29 from (67.241.15.3):
In Reply to: Re: 674 Diesel (Hydraulic Problem) posted by RAS on July 18, 2003 at 14:45:00:
I replaced the filter and fluid.
It worked for a minute now it's doing the same thing, however if I load the auxilary remotes
(handle down on the right side under the lift arms control) everything works fine but as soon as I release handle everything stops.
I can also hear what sound like a load on the engine when this handle is engaged.
Post A Followup
: Re: Re: Re: 674 Diesel (Hydraulic Problem)
