farmall h valve adjustment
Posted by ed jonas on July 20, 2003 at 05:56:06 from (65.167.43.24):
Can anyone tell me the correct way to adjust the valves on my '44 H? I know I have to get #1 cyl.on tdc compression to do adjustment. Can I check this by turning engine over till the rotor is pointing to number 1 spot on the cap and the timing marks are aligned or is this incorrect?Also is it correct to do numbers 1 and 4 at the same time and then numbers 2and3?Is there a timing mark to use for this second adjustment?
Post A Followup
: Re: farmall h valve adjustment
