Re: Generator/ alternator your thoughts
Posted by Haas on July 21, 2003 at 05:34:29 from (12.65.1.136):
In Reply to: Generator/ alternator your thoughts posted by Jim in Ontario on July 20, 2003 at 22:41:12:
Cheapest route is probably to convert to 12 volt alternator. However, if I did not have anything, I would go with a 12 volt generator and regulator. That looks original, but gives you the advantage of 12 volts. With the H, you will have to find a small alternater that will fit under the hood in the generator location, so that may make the conversion to alternater a little more expensive. The 6 volt generator will also work well. The tractor with magneto uses no current when running, so it does not take that much to keep the battery charged.
Post A Followup
: Re: Re: Generator/ alternator your thoughts
