One Brake Out, Power Steering Out, Now Hydraulics
Posted by Looking for IH Bug, RAS o on July 21, 2003 at 08:47:29 from (67.241.68.72):
I have a 674 diesel that the PTO and Power steering comes and goes, PTO will start if I raise the control arms. If I raise the auxliary outlets (lower right side handle by the right foot step) everything works, has soon as I release everything stops. I can hear what sound like the engine under a load when I engage the auxilary outlets, Am I causing high pressure verses low pressure when activating the handle? IH Bug and RAS thanks for your help thus far. IH Bug Yes, I lost one brake just before everything went to crap. after the tractor had sat thru winter I noticed the left brake was alittle weak (I thought maybe a bad mastercylinder) I started mowing hay with a conditioner and about 15 acres in I started losing PTO speed, I checked fluid and was alittle low (Not quite to the low mark on the stick) so I added some and the PTO worked fine and I finished up mowing. the next day I hooked the tedder/rake up and headed to the field as I started I didn't think the PTO seemed just right with the RPM. I adjusted the control arm and noticed the PTO speed had increased with the movement of the arms. I returned to the Barn to check filter. Thanks to RAS I located the filter and changed the fluid. I did noticed some fine shavings in the Hy-tran oil but not alot. the oil in the filter was quite dirty so I drained the fluid and changed filter and fluid. My problem still persist. What is the fix for this? take everything out and replace the MCV. Should a International Dealer do this repair? Is there a repair manual for this tractor, if so which one is the best. This tractor has 6200 hrs of Mostly bush hogging and baling :) Any help would be appreciated greatly!!!!! Thanks Kevin
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
