Re: Does my 51' H have hydraulics?
Posted by Rich on July 21, 2003 at 23:28:37 from (152.163.253.102):
In Reply to: Does my 51' H have hydraulics? posted by Adam on July 21, 2003 at 21:35:45:
Yes, your H has hydraulics. The caps you see are the pressure ports. The pump is behind those caps and inside the frame. When this tractor was converted to 12 volt, they probably used the original starter, which is OK as long as you don't grind away at it.
Post A Followup
: Re: Re: Does my 51' H have hydraulics?
