Re: Re: I Did it Now !!!
Posted by Dhuth2 on July 23, 2003 at 19:45:23 from (198.81.26.207):
In Reply to: Re: I Did it Now !!! posted by scotty on July 23, 2003 at 06:48:27:
Is the crankshaft threaded where you can screw a bolt in but not snug up against pulley and push against bolt head?..as for forcing screw tip.......I would try a smaller shaft with a slightly smaller hole then the forcing screw tip then heat and install over tip.....let cool and work it around if it isn't real tight you might get it to work out....good luck...
Post A Followup
: Re: Re: Re: I Did it Now !!!
