Re: 1948 Farmall C
Posted by Brian Schmidt on July 23, 2003 at 20:11:12 from (12.215.48.174):
In Reply to: 1948 Farmall C posted by Bob Lee on July 23, 2003 at 14:04:44:
This block is a load check valve. It prevents the cylinder from drifting and extending under a load. It is a crucial saftey item. However, you can plumb around it with just some pipe couplings until you fix the leak on the block or find a new block. Any good hydraulic supply house can get you one. It probably won't look like the origional, but it will work. Just ask for a load check valve.
Post A Followup
: Re: Re: 1948 Farmall C
