Re: starter problem?
Posted by d.Cushion on July 27, 2003 at 14:06:12 from (205.188.209.140):
In Reply to: starter problem? posted by d.cushion on July 26, 2003 at 19:15:35:
Yep I did everything Yall mentioned then I took the starter off .using the old bench test I found that it will bearely turn so its off to the starter shop tommorrow.However as I was fooling with the starter Inoticed a wheel seal leak.At least I know what my next project is.farmalls forever.
Post A Followup
: Re: Re: starter problem?
