Re: Re: Electrical problems!
Posted by Bob M on July 27, 2003 at 16:44:02 from (66.66.126.3):
In Reply to: Re: Electrical problems! posted by 49....Let me add this! on July 27, 2003 at 16:08:01:
From your description it sounds like your charging system is working as it should. My only concern is charging 20 amps with the lights on - the combined load of lights and 20 amps charge may be more than is good for the generator. You might consider replacing the cutout with a voltage regulator matched to the generator (get a regulator for an MD). The regulator will automatically control battery charging - is better for the battery than the operator guessing where to set the light switch. Also the regulator will limit generator output current to a safe value whether or not the lights are on.
Post A Followup
: Re: Re: Re: Electrical problems!
