Re: Clutch Disk - Backwards?
Posted by Theman on July 28, 2003 at 11:31:31 from (12.19.86.5):
In Reply to: Clutch Disk - Backwards? posted by NewGuy on July 28, 2003 at 06:38:09:
You may simply need to adjust the fingers on the pressure plate. The three screws need to be turned in to move the pivot points ahead. This is to allow adjustment of the fingers as the pressure plate and clutch disk get thinner from wear. I don't believe you can put the clutch disk in backward. The dished "slinger" should be toward the flywheel. If it is backward, the rim of the slinger would interfere with the pressure plate ID.
Post A Followup
: Re: Re: Clutch Disk - Backwards?
