OK,Bob!(or anyone) I changed it! Heres results!
Posted by 49 Cubber! on July 28, 2003 at 15:25:37 from (206.74.216.73):
Replace cutout with a regulator and wired accordingly.(Used your diagrams of course)Only difference was I had no "L" terminal on the regulator I bought,so I wired it as if the OLD feild wire was the wire that would have been on the "L" terminal,but put that wire on the "BAT" terminal.Is that ok?! now results of the change over.Pull out hte switch,amp gauge drops to -6,start it up at half throttle gauge goes up to around 5 amps and at full throttle dead on 10 amps!Now at midlow to low idle I get a negative reading,-5 to-8,BUT the longer it ran the closer back to 0 it would get.After about an hour of running a low idle,it was at +1 or +2.I fiqured the battery had gotten low from al the starting I have been doing,so i let it sit for about 2 hrs and started it back up with the same -5 to -8 results and again the longer it runs the closer back to 0 it gets.What does that sound like? (I did polarize)
Post A Followup
: Re: OK,Bob!(or anyone) I changed it! Heres results!
