TD-18 head gasket rings - help!
Posted by James on July 28, 2003 at 18:27:50 from (210.55.57.143):
Forgive me if this post is duplicated. I'm not sure where my first attempt went. Plus where did the crawler forum go? I/we have have been having trouble with a TD-18A or actually UD-18A Ready Power 57 KVA gen set that we aquired recently. It had numerious problems that we have worked through including water leaks into several cyclinders and into the sump. THe previous (bush) mechanic didn't tourque down the head properly we suspect. We fitted a new head gasket replacing the existing non-orignal solid copper head gasket thinking that would fix the problem as we could see tracking accross the old head gasket. We found though that we still had leaks, more in fact. Pulling the head (again) has showed leaks on all cyclinders. We have since found the liners are leaking and have pulled them out and will refit with new seals etc. But the concern we have is that it should not have leaked past the head gasket rings? With the new head gasket has things got out of tolerance? Everthing measures in tolerance but I'm not convinced the gasket rings (steel) are sealing. Has any one had simular problems and can offer anything to help?
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
