Re: Fast hitch help!!
Posted by Hugh MacKay on July 29, 2003 at 16:48:36 from (209.226.106.17):
In Reply to: Fast hitch help!! posted by Jason B. on July 29, 2003 at 15:28:50:
Jason: There is absolutely noting unsafe in regards to pulling with a fast hitch. The only reason I can see that officials don't you pulling with your fast hitch is your can use your draft control and hydraulics to gain an advantage over other tractors. I my opinion your problem is all about the whimps without that advantage. I say if your tractor was designed with that advantage, then it must be a better tractor, for pulling at least.
On the east coast of Canada we used to haul logs on sled type devices we called scoots. They had runners turned up on both ends. with the use of slip links you could put the pull chains on either end. When those big Farmalls with fast hitch came out in the 50s it sure put those 6 cylinder Oliver and Cockshutt guys in there place. These sleds were used on bare ground. Lot like a tractor pull, except you had to start the full load. Now that will sort out the good operators. Back in those days we even had tractor pulls like that, whatever tractor could start the highest percentage of it's own weight, and move it 8 feet.
Post A Followup
: Re: Re: Fast hitch help!!
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
