Re: Re: C oil filter number
Posted by jal-SD on July 31, 2003 at 11:31:52 from (12.17.66.98):
In Reply to: Re: C oil filter number posted by Chet Glenn on July 31, 2003 at 10:53:43:
A's, B's C's & Super A's (except for the last few Super A's) all have C-113 engines, they are IH's own engines, not Continentals. (IH did use a Continental in its 350 diesels, though.) Filter is the same one for all, as well as the the C-123's & H's with the short filter. The Fram # is C-135, if you don't like Frams, you can cross reference it. BTW, I've been using Frams for years, w/o any problems. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Re: C oil filter number
