Re: Re: Farmall M running rough after rebuild
Posted by MIKE ODONNELL on July 31, 2003 at 16:50:13 from (65.115.243.100):
In Reply to: Re: Farmall M running rough after rebuild posted by Van on July 31, 2003 at 15:29:33:
CHECK YOUR MANIFOLD IT MAY BE CRACKED ON THOSE CYLINDERS. WHEN YOU TOOK IT OFF IT WARPED AND WHEN YOU PUT IT BACK ON IT CRACKED SUCKING AIR AWAY FROM THE CARB. i'LL PUT A MILLION DOLLARS ON TI.
Post A Followup
: Re: Re: Re: Farmall M running rough after rebuild
