Re: Another Starter Question
Posted by Jeff-OH on August 01, 2003 at 14:15:13 from (205.188.209.140):
In Reply to: Another Starter Question posted by Kevin on August 01, 2003 at 05:51:19:
Kevin, That starter should slide right in and bolt in with no problems at all. One thing to check on while the starter is off is wear on the teeth on the flywheel ring gear. I thought I was having a problem with the bendix in the starter on mine but found out the problem I was having was from a worn ring gear.
Post A Followup
: Re: Re: Another Starter Question
