using 3pt hitch conversion bars on 2pt fast hitch
Posted by rad on August 02, 2003 at 02:05:17 from (12.208.81.67):
There are two types of converion bars, straight 26" and bent 32"
How do you know which to use?
Thanks
Post A Followup
: Re: using 3pt hitch conversion bars on 2pt fast hitch
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
