Re: Re: HELP with FARMALL H TIMING MARKS
Posted by Bob in SE Nebraska on August 03, 2003 at 08:29:07 from (162.40.71.147):
In Reply to: Re: HELP with FARMALL H TIMING MARKS posted by SCOTT IN MO on August 03, 2003 at 07:41:06:
I wonder if a mechanic added some marks when the engine was worked on before. I just checked the marks on an M and the marks for the crankshaft are a single mark that is kind of round in shape. The marks for the distributer are double and are a flatter punch mark. The marks for the distributer are kind of hard to see. If you are lucky you may be able to find the original factory marks and ignore the additional marks.
Hope this helps, Bob
Post A Followup
: Re: Re: Re: HELP with FARMALL H TIMING MARKS
