Re: HELP with FARMALL H TIMING MARKS
Posted by SCOTT IN MO on August 03, 2003 at 07:41:06 from (198.70.13.103):
In Reply to: HELP with FARMALL H TIMING MARKS posted by SCOTT IN MO on August 02, 2003 at 20:02:39:
the problem is the punch marks on the cam are are double on one side and single on the other there are no two teeth marked the double marks are beween the teeth so there is no way to line the single mark tooth on the crank between the double mark teeth on the cam . the mag gear is also the same can't get the tooth between the gear makes more sense to match double marks on cam to double marks on mag.and single marks on crank to single marks cam . thanks for the help
Post A Followup
: Re: Re: HELP with FARMALL H TIMING MARKS
