Re: Farmall M sputters under a load only when well
Posted by CNKS on August 03, 2003 at 17:25:52 from (207.178.96.211):
In Reply to: Farmall M sputters under a load only when well war posted by Brent Combs on August 03, 2003 at 12:00:47:
Also check the screen inside the carb fitting the fuel line screws into. It is also possible, maybe not likely, that the float is set too low. An indication would be if it runs better with the choke partially closed. If it does not do this until warmed up, but runs better when cold, it sure sounds like the coil or condenser, but if you are sure they are ok??
Post A Followup
: Re: Re: Farmall M sputters under a load only when well
