Farmall Tractors Discussion Board
Re: PTO shaft diameter on an H
Posted by Stan(VA). on September 23, 1999 at 05:16:11 from (207.172.109.28):
In Reply to: PTO shaft diameter on an H posted by Pat on September 22, 1999 at 15:11:41:
You have an early H, probably '43/'44 or earlier. A's B's and H's all came with the 1 1/8" PTO until all standardized on the 1 3/8" PTO in about '44(?). You can get a 1 1/8 to 1 3/8" adapter, or one better if you are going to bushog is to get an overiding coupler that has a 1 1/8 female and 1 3/8" male connections. I believe Agri-Supply and probably others have them. Check the host of this board, then try www.agri-supply.com. They carry all sorts of PTO parts, have an 800 number and they ship also.
Stan(VA).
Post a Followup
: Re: Re: PTO shaft diameter on an H
