Farmall Tractors Discussion Board
Re: Re: PTO shaft diameter on an H
Posted by ltf in nc on September 23, 1999 at 05:40:52 from (206.228.213.184):
In Reply to: Re: PTO shaft diameter on an H posted by Stan(VA). on September 23, 1999 at 05:16:11:
A nice over running clutch is available @ 1-800-345-0169. My cost was $42 delivered. You will have to grind a small notch on the side of the PTO if your shaft does not already have one. It only takes a couple of minutes. Be sure to tell them you want 1 1/8" on the tractor side.
Post a Followup
: Re: Re: Re: PTO shaft diameter on an H
