Re: Super H Hydraulics
Posted by Hugh MacKay on August 06, 2003 at 03:22:17 from (216.208.58.150):
In Reply to: Super H Hydraulics posted by Hoosierbuddy on August 06, 2003 at 02:06:30:
The oil you use will not change a thing on lifting capacity. Having said that your system should lift the 4 row cyclo full of seed and fertilizer. In fact it should play with it. I used to plant some with my 300 and same planter, same pump although persure relief and other valves may be different. What I have seen of these tractors back when they were new is Super H's in fact all H's had an edge on the 300, for lifting capacity. It sounds as though your pump may not be right up to snuff.
The single biggest reason I planted most of time with 656 was power. Comfort and manuverability were also quite large factors. My 300 had seen better days when I bought the cyclo planter in 1975, and I found it just a bit lacking on power even on level ground. On the hydraulics end I actually liked it better than 656. I shouldn't knock the 300 too hard on the power end either as it did run the planter, but was at it's limit most of time.
Post A Followup
: Re: Re: Super H Hydraulics
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
