Re: Re: clutch clearance question
Posted by Diana on August 10, 2003 at 16:36:57 from (205.188.209.140):
In Reply to: Re: clutch clearance question posted by JB on August 10, 2003 at 16:26:24:
>>>>>One of the possible reasons that the clearance can no longer be achived is that the clutch friction disk is worn. As the clutch disk wears the pressure plate fingers clearance to the release bearing decreases.<<<<<<<<
I don't understand this since even when the clevis is not attached, there is still not enough to adjust. The pedal stop is hitting the bearing cage and I see no adjustment there to raise the pedal to the required 6.5 inches.
Also, how would I know if the release bearing is rotating constantly? I'm mostly deaf so would not be able to hear that. Is there another way to indicate this?
Thanks for your help!
Post A Followup
: Re: Re: Re: clutch clearance question
