hydrolic fluid in motor oil
Posted by one row on August 10, 2003 at 17:21:55 from (67.232.147.1):
Is it possible for hydrolic fluid to leak into the engine oilpan on a Super C? I changed the motor oil in back in the spring, I check the oil before every use and figured it should use a little oil. I have never had to add any oil, so I opened the upper cockpit to check the oil and just let it drain until to stopped.It drain about two quarts of black oil,no water,hydrolic fluid possibly. I wonder how long I have been running it like this.Have I damaged the engine running it like this and what is the fix?? Thanks for any advice.
One Row
Post A Followup
: Re: hydrolic fluid in motor oil
