Re: International Excavator
Posted by Jailkeeper on August 13, 2003 at 07:14:32 from (216.174.170.188):
In Reply to: International Excavator posted by Carol Martin on August 13, 2003 at 05:23:02:
Carol, I would guess there should be a check valve in the pump somewhere to prevent the fuel from bleeding back out of it. If not, there could be a hole in the diaphram as you said.
It would be possible to install an electric pump to supply the mechanical pump. I think any pump that produces 5-10 psi would be sufficient if you wanted to go that route.
Post A Followup
: Re: Re: International Excavator
