Re: 504 wide front
Posted by Todd Frampton on August 13, 2003 at 19:13:46 from (209.195.168.40):
In Reply to: 504 wide front posted by Kevin on August 13, 2003 at 18:34:28:
Kevin,
I have a 1962 504D that was originally NF. Purchased with an Oliver wide front in 1998. I did some work to it by spinning the front 180 degrees (so the front axle was more forward) and made custom steering linkage with hiem rod ends (one long rod from steering knuckle to knuckle like 1975 Ford 4x4 trucks) and one tie rod from center pivot to pass side knuckle. Works good. Just have to make center bracket so last tie rod is at sufficient angle for proper turning radius side to side.
Todd
Post A Followup
: Re: Re: 504 wide front
