Re: timing gear failure - C123 engine Farmall200
Posted by RPM on August 14, 2003 at 07:05:00 from (209.152.115.185):
In Reply to: timing gear failure - C123 engine Farmall200 posted by RayP(MI) on August 13, 2003 at 18:47:47:
C/SUPERC/200/230 were all same engine basically, drive gears will fail after many years, when they first designed these engines no hyd pump was mounted. They lasted quite a while after they put on pumps so IH wasnt really aware of these failures till way later. If it lasts 40 years or more that really isnt bad.
Post A Followup
: Re: Re: timing gear failure - C123 engine Farmall200
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
