Re: H - Crank doesn't line up?
Posted by Aces on August 15, 2003 at 10:37:50 from (67.0.38.25):
In Reply to: H - Crank doesn't line up? posted by Brad on August 14, 2003 at 19:05:03:
Have I misted some thing heer never new a Farmall to have rubber motor mounts. Your broblem is more likly to be the front bolster bolts came loose like many old tractors that had lock washers on the frame bolts and the bolster is out of line. Put in new grade 8 hard screw in the frame and leave the lock washers in the store where the belong. If hole in rail is over size use a grade 8 hard washer on the hard screw. All makes had thisproblem untill the left off the lock washers. Take a look at a new tractor like a 706 656 806 noe lock washers never had one come loose.
Post A Followup
: Re: Re: H - Crank doesn't line up?
