Re: Re: H - Crank doesn't line up?
Posted by CNKS on August 15, 2003 at 18:49:00 from (207.178.96.213):
In Reply to: Re: H - Crank doesn't line up? posted by Aces on August 15, 2003 at 10:37:50:
Justin is correct, I knew the frame rails were different, but did not know about the motor mounts (ignore my post below). My parts book indicates that the change occurred at SN 96813, or early 1942. I need to remember that when I start tearing down my 1941 H. I will keep your comment about the lock washers in mind. I currently have a Super H disassembled, don't remember if it had lock washers on the frame bolts or not. Will check during reassembly. A lot or those old bolts should be repalced anyway.
Post A Followup
: Re: Re: Re: H - Crank doesn't line up?
