Re: Farmall H oil pump
Posted by Theman on August 15, 2003 at 12:29:25 from (12.19.86.5):
In Reply to: Farmall H oil pump posted by SCOTT IN MO on August 14, 2003 at 20:15:26:
The H oil pump wasn't really designed for rebuild. I have taken two so-so pumps and made one from the best parts. It works great and produces a lot of pressure, but I do NOT recommend this. It was a lot more trouble than just getting a good pump somewhere else.
The gasket set for your rebuild will include a couple of shims for the bottom plate. They won't be necessary if you get a good pump. Put them in a safe place in case you need them later.
Post A Followup
: Re: Re: Farmall H oil pump
