Crack in rear end housing on M Farmall
Posted by Rod on August 17, 2003 at 19:24:41 from (12.24.198.176):
Hi. Just recently bought a 52 M Farmall. I didn't notice until I power washed the tractor and got all the old crud off of it that the housing for the rear end had a crack in it and was leaking fluid. A mechanic told me that at some time a breaing must of dropped down and got picked up by the gears and this caused the crack. If so does anyone know of a good way to fix this crack?? It's in the front about two inches in from the side below the fluid level.
Thank's in advance for anyones help.
Post A Followup
: Re: Crack in rear end housing on M Farmall
