Re: Crack in rear end housing on M Farmall
Posted by Michael Soldan on August 19, 2003 at 18:48:34 from (216.46.130.65):
In Reply to: Crack in rear end housing on M Farmall posted by Rod on August 17, 2003 at 19:24:41:
Rod, I discovered an H that I bought had the same break. I took it to a local welding shop where we drained the rear end and then he welded it up and ground it off smooth. It is a perfect fix, does not seep and is not noticeable. This chap is an expert welder , there are places I would not take a job like that. The rods are very expensive but in the end it was worth every cent...Mike in Exeter Ontario
Post A Followup
: Re: Re: Crack in rear end housing on M Farmall
