Re: H CARB PROBLEMS
Posted by Bill Smith on August 19, 2003 at 14:23:09 from (63.147.130.141):
In Reply to: H CARB PROBLEMS posted by FARMIN RED on August 19, 2003 at 05:34:50:
Two possible causes. With gas turned on under the tank the carb should not leak out gas like you were saying. If it does, then you got a float and needle valve problem inside the carb. If it only does it for a little bit after choking, then you are simply overchoking it. If this tractor is in fair running condition it should only need very minimal full choking to start. If I need to choke mine, I go all the way and let all the way off right away while cranking. Very rarely do I need to parshaly choke for the tractor to run (only during cold weather untill tractor is warmed up).
Post A Followup
: Re: Re: H CARB PROBLEMS
