Re: Super C Two Point Hydraulics
Posted by DHuth2 on August 19, 2003 at 20:39:59 from (198.81.26.207):
In Reply to: Super C Two Point Hydraulics posted by Bud on August 19, 2003 at 12:38:33:
I believe what you have there is a load check valve....its purpose is to prevent any oil from leaving the rod end of the cylinder unless there is a slightly higher pressure on the base end supply or vise versa. It will prevent cavitation of cylinder when you are lowering with a reduced GPM like when you are idling or when pump is not pumping. We use them alot on hyd. motors to lock them from turning or from overspeeding when turning an unbalanced load. The valve will have a shuttle and spring and a couple of seat assemblies sometimes using balls.I bet that if you have a two way cylinder and don't run tractor , the hitch will lower when you push lever now.Hope this helps....
Post A Followup
: Re: Re: Super C Two Point Hydraulics
