Re: Re: Re: IH Super M Generator question
Posted by Bob M - another tip... on August 20, 2003 at 05:58:32 from (165.170.128.66):
In Reply to: Re: Re: IH Super M Generator question posted by Chad on August 19, 2003 at 12:32:42:
Thanks for your kind words Chad!
Forget to mention in my previous reply: If you're in a hurry to get bailing, simply slip the belt off the generator. So long as the battery is good and is fully charged when you begin, it should run the tractor ignition 8 - 10+ hours without the generator working. Then at the end of the day put it on a charger and let it recharge overnite. To get maximum run time minimize use of the starter, and DON'T use the lights!
Good luck!
Post A Followup
: Re: Re: Re: Re: IH Super M Generator question
