Re: Re: Re: Cub is home now.....needs a few things
Posted by Bob M on August 20, 2003 at 10:20:50 from (165.170.128.66):
In Reply to: Re: Re: Cub is home now.....needs a few things tho posted by Carm on August 20, 2003 at 09:46:53:
Carm - Take a close look at the carb shaft. Some carburetors let you put the choke shaft in from either side. Could be someone before you had the carb apart and simply assembled the choke shaft back on the wrong side. If so a couple minutes and small screwdriver can make it right again.
Post A Followup
: Re: Re: Re: Re: Cub is home now.....needs a few things
