Electrical System Troubleshooting
Posted by Chad on August 22, 2003 at 06:50:19 from (206.230.0.170):
I posted a message a couple of days ago about electrical system charging troubles on my SMTA. Well, last night I was going through the generator/regulator troubleshooting flowchart that Bob M has put together (very helpful) with some interesting results that I was hoping someone could help interpret. 1. With the engine and electrical switch off, the ammeter needle is just below "neutral" (no charge or discharge) in the discharge area of the meter. Is the needle supposed to read straight up at "neutral" when the switch is off? (in other words, could there be a calibration issue with the meter or does it really matter?). When the switch is turned on, the needle drops further into the discharge (can I assume the ammeter is OK?). 2. I ran a ground jumper from the regulator base to ground. No charge. 3. This is the interesting part. When I jumpered between "BAT" and "GEN" terminals at regulator, the ammeter needle shot deep into the DISCHARGE realm, not charge. When I disconnected the jumper, the needle returned to the previous discharge level. Does this indicate a bad regulator? I'll probably go ahead and replace this per advice from a previous post, but I was curious as to why it would drop into discharge like that. 4. While I had the multimeter out, I decided to check voltages between different points in the system. I noticed while the engine was running, there was approximately 5.8 volts between the F terminal on the generator and the L terminal on the regulator. When I increased RPM, the volts dropped to 5.2. With the engine off and switch on, the voltage is negligible. Would this indicate that the generator is working? Thanks a bunch for any input or advice and I apologize for my lack of know-how and experience. Chad
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
